How to display the Machanica Mesh
amedina
One of the users is using mechanica and wants to know how to display a mesh
he just created. Can someone point to me to the setting. I recall a mode
where one can see surfaces is Blue, edges in black and nodes in yellow to
review the mesh.
regards,
Alfonso
> a
> mesh he just created. Can someone point to me to the setting. I
> recall
> a mode where one can see surfaces is Blue, edges in black and nodes
> in
> yellow to review the mesh.
> regards,
> Alfonso
What version of Pro/E are we talking about here?
Do you want to see the mesh in the Pro/E model or in the result
windows?
For WF4:
In the result windows you can do
Edit; Result Window; Display Options; Show Element Edges
In the Pro/E model you can do
AutoGEM; Create; File; Copy Mesh from Study
and you can tweak the settings using
View; Simulation Display; Mesh
Alternatively, for the hardcore users, you can switch to Pro/M
standalone, if you have that, but that method is deprecated 😉
Best regards,
Patrick Asselman
Hi Alfonso,
As far as I know, you can generate (or retrieve) the mesh using the
'mesh' toolbutton whilst editing the Mechanica model; or you can select
Show Element Edges in the Result Window Definition dialogue box.
There may be other options in Independent Mode, but I only use
Integrated Mode.
HTH,
Jonathan
