The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
How to fix an invalidated key frame sequence in Creo Parametric animation?
lrafter
1-Newbie
I created several snapshots to make an animation with in Creo Parametric.  I created the key frame sequence, but when I try to play the animation I keep getting the following error "Key frame sequence Kfs1 invalidated and will be ignored."  What does this mean?  How did I get an invalidated key frame sequence and how can I correct it?  Has anyone had this problem before?  I am not sure where to start because I did the process exactly as I have before, and it worked previously.
2 REPLIES 2
Setting all the bodies to desired resolved the issue.  Don't know why the bodies can't be unspecified or required on this animation though.
gkoch
1-Newbie
(To:lrafter)
duplicate thread - see How to fix an invalidated key frame sequence in Creo Parametric animation? under main community PTC Creo
(anyway, thanks for adding the answer)
