I recently added a windchill server in Creo.
Post addition, all my files get stored in my workspace and it crashes often.
Kindly help me out to remove the workspace and the windchill server, unable to delete it.
Deepak
if you are using Windchill, then your company has to have system administrator knowing your internal rules and seetings. Ask him for a help
MH
You cannot remove the last workspace from within Creo, you need to use a web browser to delete it.
Once that is done, you should be able to delete the server registry setting.
Deepak,
You can disconnect Creo from Windchill from Server management (File > Manage Session > Server management > Double click on NO server )
