How to set envelope dimension to visible portion only (hide in layers should not consider)?
Level 9
Currently, while calculating envelope dimension, creo considered all portion of components in assembly.
But i want to know how to find envelope dimension for visible components only (if unwanted components are hide in layer). So the parts which are hide in layer should not consider to calculate envelope dim.
Is there any config option or else workaround?
Prashant Pandarkar
Level 8
Re: How to set envelope dimension to visible portion only (hide in layers should not consider)?
Hi, Don't hide in layer as they are still present. Create a simplified rep and exclude the parts you don't need. This should give you new envelope
Level 20
I have not tested this but logic tells me you need to suppress the components you wish to ignore in the calculation.
Alternatively, you may be able to use family tables for this.  Simplified reps?
You will have to test these options for your particular use-case.
I suspect you will find reasonable alternatives to layers and visibility.
Level 9
Okay.
That i will check and update.
Prashant Pandarkar
Level 9
Suppress might not work, as we already having a check to catch suppress component in model before it goes to PLM.
So might be another option like simplified rep is useful, will check that and update.
Prashant Pandarkar
__________________________ Creo 5.0 Sneak Peek Creo 5.0 is scheduled for release in March 2018, but we’re giving an early opportunity for Creo users who don’t want to wait! In the Creo 5.0 Sneak Peek you’ll be able to test enhancements before the official release.
Fill out the Creo 5.0 Sneak Peek Sign Up Form For questions, please reach to SneakPeek@ptc.com
