How to split curve in creo parametric 2.0?
rnithinmanohar
I imported a curve(iges format) to creo parametric,
I want to know how to split that curve, help me
thanks
you can 'trim' curves in the 'Editing' menu.
You can use various elements as trimming references, such as points, datum planes, etc.
In case you want to keep both sides, you need to toggle the direction twice (third time brings you back to the first direction).trim3.jpg
5 REPLIES 5
Hi Constantin,
     Thanks for your replay,
If we use trim option, then portion of the curve is going to be deleted.
I want to split the curve but complete curve should be there
that is exactly what I describe in the last picture: if you toggle the direction twice and get the double arrow, the curve is split, you keep both sides that afterwards you can select as separate entities.
Hi Constantin,
Its working,
Thank you
rayudu nithin manohar
Don't forget to make the appropriate answer as correct.
Thanks, Dale
