How to swap colume on 2D repeatregion?
PeerapongSarath
8-Gravel
Dose anyone know How to swap or rearrange the PARAMETER Column on the 2D repeatregion? Appreciate, Peerapong
4 REPLIES 4
open the family table, select the first column, then CTRL+select the second one, now both are selected, go to edit, swap the column.....
I am having the same problem. I would like to re-order columns in a drawing 2D table, created from a family table in the model. Any ideas?
Hi Dwight
I would suggest he same as replied in the earlier post
Go to the family table of the part
swap the columns as per your requirement;
This will automatically reorder your columns accordingly in the drawing
Regards
K.Mahanta
