Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Hi Chris, click "Tools->Customize Screen". In the Categories choose "View" and then on the right side the command "3d notes display". Click it with the left mouse button and move it to the top. Good Luck! Regards Jürgen
OMG, it is a new defaulted icon on the toolbar, next to turn on/off datums, axis, point, csys. I did not see it until you mentioned it in the post. I went to the Tools->Customize Screen and saw the icon and then noticed it was the same as the icon already on the toolbar. Ha, funny. Thanks Juergen
