Hi all,
i have been trying to figure out how to write a relation, but without success. I have a parameter P1 which has a string value of 2A. I am trying to make the diameter of a cylinder = 102mm if P1 = 2A, so how do i write this? I tried the following but it did not work
IF(P1==2A)
d233=102
ENDIF
I guess a string value cannot be used in a relation in this way.
Regards
John
Hello John.
In to relation you can write a parameter with string value - do you need add an apostrophe - in your case: '2A'
For example:
IF(STRING_PARAM=='2A')
d6=d4
ENDIF
Note: you can not use P1 parameter - this parameter is reserved by system
Hello John.
For example:
d6=d4
ENDIF
Thank you Vladimir, that worked for me.
Best Regards
John
