I am in Creo Parametric Format (.frm) model.
avaerten
I revised my format to be 1422.4 by 863.6.
But my SIZE tag at the bottom of my display screen is showing 1397 by 863.6
I select the SIZE tag and do a “Define”.
I update the “Grid Outline” and the “Grid Origin” by the SIZE tag never updates.
So how do I update the SIZE tag?
TomU
(To:avaerten)
You can change the size of a drawing but you cannot change the size of a format after it has been created.  Moving lines or changing the grid size will have no impact on the sheet size of the format.
Hello Al,
Thanks for posting this question. I'm moving it from the eSupport Help community to the Creo Modeling space, where it will find the right audience. Please don't forget to mark correct if the answer from Tom below has clarified things for you.
