I ran 6 cases with differente loads, now, how do I know what was the load at 1st case?
AntoniodeItaVen
8-Gravel
Hello world,
Look, I ran an analisys where I had to evaluate with different loads. After a month I had to go back and verify the stresses and deflections, the problem is that I do not how to show the load value is for case 1.
for last case it is not a problem, I just check edit and I can see the numeric value, but for prevoius cases the only thing that I can see is the stresees, deflections and so on but the load applied for teh calculation,
see file attached
Does anyone knows how to get it?
I appreciate any help
thanks
‌If i remember correctly, each analysis has its own folder, and inside this folder there is a .prt or .asm file that you can open in Creo. Make sure to erase not-displayed parts before opening. This way you should be able to investigate the model.
2 REPLIES 2
Thanks Patrick,
that is the right thing to do.
I appreciatte the help
Thanks again
