IF Diameter
wfalco
IF Diameter
Is it possible to add a temp relation that says IF a diameter = 5.18,
then make it = 5.00? Gotta lotta holes to change and thought maybe I
could change them in one fell swoop.
4 REPLIES 4
TomU
(To:wfalco)
Are these all in one model, or many models?
Exact syntax for one diameter is this (replace DIAMETER with the dimension name):
IF DIAMETER == 5.18
DIAMETER = 5.00
ENDIF
Tom U.
wfalco
(To:wfalco)
Sounds good.
I tried and get this...
IF DIAMETER == 5.18
errorInvalid symbol 'DIAMETER' found.
DIAMETER = 5.00
ENDIF
BenLoosli
(To:wfalco)
Replace DIAMETER with the parameter that is originally driving the diameter dimension.
IF p254 == 5.18
P254=5.00
Endif
If all of the holes are in a pattern then this should work, but 1 edit to the master hole will do the same thing.
If your holes are defined independently, then nothing will work, unless you have changed them to use a defined parameter for the diameter.
Thank you,
Ben H. Loosli
USEC, INC.
DonSenchuk
(To:wfalco)
You could try using Edit Program, which opens in a text editor, and replace 5.18 with 5.00. If there are no dimensions at 5.18 that you want to preserve, just to a mass replace.
In Creo2 it's:
Tools > Model Intent > Program > Edit Design
(Warning, if it's an assembly, you'll need Advanced Assembly to use this.)
In Reply to Wayne Falco:
