INSERT/G5 P10000
GeorgiosLaboura
INSERT/G5 P10000
Dear Pro/mfg Gurus,
In the customize tab I am inserting manually the following command.
INSERT/G5 P10000
The selected option in cl command is Current.
In the customize tab the additional command appears as following:
Thank you guys for your help,
The format that worked is, INSERT/G5 P1000$
( $ at the end )
Thank you all.
Georgios L.
