ISO tolerance table
SOLVED
Level 1
ISO tolerance table
Is it possible to have the ISO tolerance tables always loaded(avoiding the step of retrieving the tables) ?
With this I can reduce a step in drawing process increasing the productivity.
  • Drawing
1 ACCEPTED SOLUTION
Level 17
Re: ISO tolerance table
I am not sure what note are you creating in a drawing.
Load ISO tolerance tables must be done in model, see following picture.
MH
Martin Hanák
Level 17
  • open model template
  • change tolerance standard to ISO
  • load ISO tolerance tables
  • save model template
  • use model template to create new model
MH
Martin Hanák
Level 1
Thanks for your help.
The tolerance definition is already in ISO/DIN. But when i want to create the note on 2D draw i have always to retrieve the tables. I want to know if there's a way on config.pro or in other file to have the tables always available.
Level 17
MH
Martin Hanák
Level 1
Ok, I always do that as you shown on the picture before.
For example, i'm a designer easily a machine in my projects have more than 100 parts, do i have to do this 100 times or is there a way to do it just once.
Level 17
YES, you have to do this 100 times.
MH
Martin Hanák
Level 1
