Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Nope, it wasn't working yesterday either (5/10/10). They updated the UI to some tree based thing and I am now getting "Document Not Found" errors with everything I try to download. It doesn't matter if it's in the latest released section or older versions. Nothing works. Hopefully technical support is working vigorously to fix the issue.
Patrick Williams Sr. Systems Engineer II Mechanical Engineering Solutions Missile Systems Raytheon Company
TU/M12/8 6221 S Palo Verde Rd Tucson, AZ 85706 USA www.raytheon.com
This message contains information that may be confidential and privileged. Unless you are the addressee (or authorized to receive mail for the addressee), you should not use, copy or disclose to anyone this message or any information contained in this message. If you have received this message in error, please so advise the sender by reply e-mail and delete this message. Thank you for your cooperation.
