I have been useing Pro/E for about 13 years, and have never had to do anything like this until today.
Is it possible to created a partial and broken view at the same time?
I am using Wildfire 4.
There is no configuration option, which would change the settings for new views.
Yes I know how to do this, but can you make both a Partial and a Broken View in the same view?
I'm not sure it is even possible, other than making multiple partial views and aligning them.
Hi
I do not think so. Maybe you can solve it with multiple breaklines.
Even in WF5 you can have your problem.
Regards
Chris
I was able to accomplish what I was looking for by making 2 partial views and aligning them together so they appear to be a broken view.
~Z
Can you explain so more as to why you need to have a broken view and a partial view in the same view?
It's hard to explain, but I have a part that is being used in 2 different areas of an assembly and they need to be symmetrical to each other and at a certain distance apart. So I need the partial view to show the the two parts and their orientation, and because they are so far apart then I need to break it, and show the distance between them.
~Z
