Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Anyone ever placed user dimensions in an isometric view? I can "show" model dims, but I need to place my own dimensions, and they do not follow the isometric model.
Been trying to do that, but everytime I try to create a dimension on the model I get the error that the dimension cannot be created. Did they really need to make this SO difficult?!
need to select the plane parallel and picke the edges to create the dim. It is not that hard first time it might be hard to create one but it is very handy tool I guess you must have set in dtl "allow_3d_dimensions" to yes. -Chander
