Isometric Dimensioning
CBenner
8-Gravel
Anyone ever placed user dimensions in an isometric view? I can "show" model dims, but I need to place my own dimensions, and they do not follow the isometric model.
Chris Benner
Autodesk ® Expert Elite
try this create annotation in the model and show them on the iso- view you should be able to get what you needed. -Chander
Been trying to do that, but everytime I try to create a dimension on the model I get the error that the dimension cannot be created. Did they really need to make this SO difficult?!
Chris Benner
need to select the plane parallel and picke the edges to create the dim. It is not that hard first time it might be hard to create one but it is very handy tool I guess you must have set in dtl "allow_3d_dimensions" to yes. -Chander
