Helllo,
How could I keep the properties of my general view when I'm creating a projection view?
Each time I have to go to properties and change my setup.
Simon Gauthier
Bain Ultra
St-Nicholas, PQ
Can you be a little more specific? Usually when you create a projection view, the projection takes on all of the properties of the parent view. Anything done to the parent will be reflected on the projection.
If you're referring to things such as the display style, they don't carry over in WF4 (unless we're missing a config option).
I can have a view set up with No Hidden, Tangent None, and when I create a projection view from it, it takes on Follow Environment instead.
I have to select each new view (or all of them together - a small time saver) and change the display settings every time.
Try setting the model_display_for_new_views options in the drawing.dtl file (drawing options).
