I am looking out for a list of limitations of using family tables in Creo 2.0 which is interfaced with Windchill 10.1. Request all of you to contribute as many points as possible. Thanks in advance.
Best regards,
Simha
Hi - best practice >> minimize family table's models in common space.
You can store it and use it, but ... many times you need to download all instances and then your workspace is a huge - for example Flat Sheet Metal part you can create as simplified
Hi Vladimir Palffy,
Thank you.
Here are some thoughts on family tables:
