Locked dimensions
jhailey
Locked dimensions
I have a project that all of a sudden the relations programs will not change dimensions in the project.  It acts like it is locked and will not let them be modified by the relations.  I can go into sketcher and manually change the dimensions.
mganzer
(To:jhailey)
Did you accidentally add any relations in the sketcher? Those would stop modification and would not show up as relations outside the sketcher.
mganzer
(To:jhailey)
jhailey
(To:mganzer)
No, I just found the problem and had an extra else stmt in my if-else stmts.  It was not allowing the code to run that I needed to run.
Thanx.
Dale_Rosema
(To:jhailey)
Hate it when the code does what you tell (or don't tell) it to do..
Yes it should always do what i want it to do not what i tell it to do.
