I have been looking forward to the M020 release.
The calendar originally stated M020 would to be available on Nov. 18th along with the first ship of creo layout 1.0.
On Nov. 18th creo layout 1.0 was removed from the schedule leaving creo layout 2.0 available sometime next spring. The creo parametric M020 ship date was moved to Nov.28th and that has now passed.
The last minute scrubbing of the creo layout 1.0 FCS launch probably required some tweaking in the creo core. We will be lucky if M020 or a tweaked version of it is available before January.
Joe
Jim, can you at least give us an update on when we should expect M020 now that the scheduled date has come and gone.
Looks like it showed up today. I spoke too soon.
Any major issues/bugs with Creo 1.0 M010?
I also need to confirm which version of Creo will work with Windchill 10. I thought it was Creo 2.0 but I could be wrong.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
I just downloaded and installed M020. It installed the PTC Quality Agent, (which I don’t want), even though I didn’t enable it under the optional configuration Steps.
At first launch it installs a “Creo Platform 1.0”. I don’t know what this is, however if the first person to launch M020 on a workstation is not an administrator it can’t install it, but tries to at each launch.
Creo Platform 1.0 puts .dlls and .creomanifests under the Program Files (x86)\Common Files directory, it looks like something I don’t need or want as well.
-Dave
