does anyone know if there is a limit to the amount of mapkeys you can have? I dont seem to be able to create any more than 83 which seems like an odd limit
Is there an error in that "83"rd mapkey that is causing the following mapkeys not to be read properly. Maybe a continuation "\" character?
We have over 200, so 83 can't be right...
that was it a rogue \ causing the issue thanks for pointing me in the right direction
