I apologize if this has already been asked and answered in a previous post but I did search the forums and was unable to locate this information.
Basically I'm looking for an aide or map where I can select a command or menu item from Wildfire 4 and it will show where it's at in Creo Parametric.
Thanks for the help........
Stacy
Stacy,
in Creo Parametric 1.0, you can use Command Search box to find requested command. See the following picture.
Martin Hanak
Stacy,
Martin Hanak
