Mapkey maximum limit of lines
James62
One of my scripts generates mapkeys that are over 1.5k lines long and I'm curious if anyone knows if there is any limit to the length of a single mapkey? Could be a maximum of characters. Is there any limit to that?
~J
Chris3
20-Turquoise
(To:James62)
Starting with Creo the maximum number of lines a mapkey can be has been increased to 1,023,996 from 32767.
In either case 1.5K should not be a problem. Prior to Creo if 32767 was exceeded, Wildfire just exited without warning.
Chris3
20-Turquoise
(To:James62)
