Maps keys CREO2, why don't "p" and "o" work?
SOLVED
Re: Maps keys CREO2, why don't "p" and "o" work?
Don't forget to mark your answer as correct so those following behind you or search on this will know that it has been solved. Thanks.
So, as I mentioned, you had 2 different mapkeys that were stepping on each other's toes? It's common.
Is a ribbon key a kind of mapkey?
It should be Dale, a mapkey is a mapkey.......unless they're talking about an icon.
any one can explain map key in creo 2.0 ... save permantely..
save the mapkeay in deafult config.pro file.
