The note creation is a3 step process.
First in the part, you set mass property (ieABS = .0379)insert a mass property FEATURE and set it to become a footer.
(Failing to make it a footer in the feature table will not include subsequent features.)
Second you write a relation in the relations pulldown command.
MASS=MASS:FID_MASS_PROP_1
Lastly in the drawing thenote would read
NOTE:
1. MATERIAL MASS: &MASS lbs
hope that helps.
I have done this without the relation.
I create an analysis feature called Mass_Analysis and place it in the footer. Then I will create a note that reads "Part Weight &mass:fid_mass_analysis[.2] LB" I use weight to not confuse the purchasing and marketing types, and the [.2] truncates the decimal places to 2. It defaults to 3. We are now looking at making this a part of our format and will be included automatically oon all drawings. The Analysis feature is a part of our start parts and assemblies.
Brent
