Material Files - Share?
pauldelong
Does anyone havea basic set of material files they can share (preferrably with appearances defined) - WF3 or later.
Big thanks in advance,
Paul
6 REPLIES 6
Check MCAD Central, I've downloaded this, but we don't do much FEA so I can't say as to the file's accuracy.
http://www.mcadcentral.com/proe/files/gallery.asp
I believe there's a zipped materials file in the Miscellaneous section.
Hope this helps,
Rodney (WF3 M140)
This has come up twice in the past few months, once my me. I didn't
respond because you asked specifically for WF3 versions.
I received a large number of material files, based on the ones at MCAD
Central, but they are all the old old format I have had no luck in
converting them. WF3 will open them, but any edits result in an
unsavable material file where the blank fields are tagged as 'invalid'.
Blank fields should be acceptable, in fact they were fine until I
changed something else.
I gave up.
Doug Schaefer
LinkedIn
Here as some that should be in WF3 format... I'm currently using them in
WF4, but converted them back in WF2 or 3...
Paul Korenkiewicz
FEV , Inc.
4554 Glenmeade
Auburn Hills, MI, 48326-1766
This would also be an excellent thing to post to the Files section of
portal.ptcuser.org, if you're willing.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
Good to know. I've only used them for mass calculations thus far when customers or our shipping dept. needed to know approximate assembly weights.
Rodney
In Reply to Doug Schaefer:
I gave up.
Doug Schaefer
Senior Project Engineer, Mechanical
www.design-central.com http://www.design-central.com
Tel +1 614 890 0202
Fax +1 614 890 5880
Design Central designet
6464 Presidential Gateway
Columbus, Ohio 43231
USA
done... to the public areas/configurations under WF3 material files...
Paul Korenkiewicz
FEV , Inc.
4554 Glenmeade
