Material Properties
sam.mulkay
Material Properties
Hey,
Can anyone point me in the right direction?
We are looking for some material libraries to use in Pro/Mechanica. Appearently it's not that common to have extended material libraries or the common properties of those.
Metals don't seem to be the problem, but now for Advanced Mechanica we need some plastics... themoplasts, thermoharder, composites (which is hard I know)
Thanks for some feedback haw to get started.
greets
sam
5 REPLIES 5
In the meanwhile I was still looking Myself and found the following
http://www.campusplastics.com/
This tool allows to have all the info needed per producer.
How to check the material properties of matel?
In ProE with a part opened go to File/Properties, on the material row clicl on "change" link, and the Edit/Properties and done.
Thanks. But I want to get more metal property,PTC provide material is not enough.
Need free register to get Miscellaneous Materials Files
Try this on mcadcentral
