Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Okay..... I just burned up half the A.M. trying to figure out how to measure in Wildfire. Completely frustrated, any suggestions? I simply would like to know the distance from one component to another. My old mapkey for measure edge to plane doesn't work in wildfire. Thanks for your responses.
I had the same problems mate Fear not, they are making big changes to the measuring in WF4, so that you dont need 20 clicks just to measure a simple distance 😛
