I am seeking assistance with the measure tool. After I click on an initial reference (which highlights in green) then click the second reference (which highlights in green and the original un-highlights itself) for the dimensinal information I need, the second reference replaces the original in the populated box and no dimensional information is given. Is this an issue with some kind of "snap" setting? I am using Creo 2.0.
Thanks for your assistance!
When using Measure tool use CTRL (Control Button) to select references, Select first Reference > CTRL > Select Second Reference.
I hope this helps.
I hope this helps.
Thank you for your assistance!
