I've used Autodesk for a year or so and they have this really handy tool to measure distances between models. I was wondering of PTC had a tool like this, and if so how to use it.
Hi
The video you have seen is in Creo Parametric 1
This is not an older version(This is the latest version)
The User Interface(Ribbon) is different, but the options are same.
You will find these options in Analysis(dropdown)>Measure
For easy use you can add these tools in your toolbars
Regards
K.Mahanta
Hi
Check the following link from Learning Exchange
http://learningexchange.ptc.com/tutorial/455/measuring-models
Regards
K.Mahanta
I apologize for not specifying which program I am using. I'm using creo elements/pro 5.0
It seems to be a much older version of the one displayed in the tutorial link you gave me, and it has a much different menu and from what I can see; No quick easy tools to measure.
Hi
Regards
K.Mahanta
