Hi everyone,
Is there an existing option for disable the automatic calculation of area and perimeter ?
Because, the calculus is too long and loose my time each time.
The Calculus of area and perimeter should be an option.
Try using the specific measure you are wanting to obtain. The little down-arrow below the Measure icon will list the specific measurement type available and also the measure dialog pop-up menu.
