Is there a menu mapper for Wildfire to Creo ?
Hi
In Creo there is a powerful tool Command Search
You can search any command you remember and move your cursor to that command
This will guide you the path of the command
I think the basic Idea behind Menu mapper was also the same
K. Mahanta
The thing I liked about the menu mapper is it showed you the old menu and were the they put it on the new menu. It was great.
Hi
When you remember the name of the command, then it is not important where the command was in earlier version.
Rather I believe it is important where it is in new version. This is the function of Command search.
K.Mahanta
To answer your question: no the menu mapper is no more
