Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Method for turning ProE model into streamlined 3D dxf?
Does anybody know of a tool or method for turning Pro/E models into very lightweight 3D DXF files? By lightweight I mean reduced polygon count along with leaving out the insides.
Thank you,
Margi S Korch Principal Mechanical Engineer Information Technology Mechanical Engineering Solutions Missile Systems Raytheon Company
This message contains information that may be confidential and privileged. Unless you are the addressee (or authorized to receive mail for the addressee), you should not use, copy or disclose to anyone this message or any information contained in this message. If you have received this message in error, please so advise the sender by reply e-mail and delete this message. Thank you for your cooperation.
