Mismatch is step file after Save As from Sheet metal part file
Level 9
Hello All
This is normal behavior for the step file which is created form the sheet metal part file? I tested by publishing and saving in local but the same result.
When we do a save as for STEP file from Sheet metal part from Creo, some features are merged in Step files
Best Regards
Tags (1)
1 REPLY
Level 20
Re: Mismatch is step file after Save As from Sheet metal part file
There are some functions that do not merge all solid geometries.
However, exporting a hem will merge them.
If you require the gap, you must provide a gap in the hem or make it a separate part.
__________________________ Creo 5.0 Sneak Peek Creo 5.0 is scheduled for release in March 2018, but we’re giving an early opportunity for Creo users who don’t want to wait! In the Creo 5.0 Sneak Peek you’ll be able to test enhancements before the official release.
Fill out the Creo 5.0 Sneak Peek Sign Up Form For questions, please reach to SneakPeek@ptc.com
