Mismatch is step file after Save As from Sheet metal part file
Gagan
7-Bedrock
Hello All
This is normal behavior for the step file which is created form the sheet metal part file? I tested by publishing and saving in local but the same result.
When we do a save as for STEP file from Sheet metal part from Creo, some features are merged in Step files
Best Regards
TomD.inPDX
(To:Gagan)
There are some functions that do not merge all solid geometries.
However, exporting a hem will merge them.
If you require the gap, you must provide a gap in the hem or make it a separate part.
