Model Tree Icons
WarrenPettus
2-Explorer
Model Tree Icons
Could someone please give me a listing of or a location of the discription/meaning of each of the Icons that are possible in a Model Tree; an example is the Double Bars, which indicates not fully constrained, etc. Thank you, Warren
5 REPLIES 5
They are actually called Glyphs - apparently.... To get the definition try the following in Pro/E: Help>Help Center In Quick Search enter Glyphs - you should get a link to "Understanding Glyphs in the Model Tree" which should help to explain them all.
"glyphs" do not come up in any searches under Help in WF3 on my computer???
http://www.ptc.com/cs/help/proengineer/wildfire40/html/usascii/proe/fundamentals/fund_six_sub/understanding_glyphs_on_the_model_tree.htm
Thanks for posting the link. I have been after an explanation of the model tree symbols for a while but didn't know they were called Glyphs. Cheers Martin Ashton
open tree setting from pro-e window and save the setting in the folder where you saved your config file & update that path in config file
