Moving along a path
Papirene
Moving along a path
Hi, is cocreate pe able to move parts/assy along a path, like an engine rod for example?
hkramer
(To:Papirene)
you would be able to get this in the professional version of Modeling with using the Advanced Design Module, which is not part of Modeling PE.
For the differences between Modeling PE and Modeling please see http://www.ptc.com/WCMS/files/100731/en/Modeling_PE2_comparison_EN.pdf
For Advanced Design see http://www.ptc.com/products/cocreate/advanced-design
You can achieve this to a limited extend by using the dynamic positioning functions and moving the parts,
but only to a limited extend and most likely not what you try to achieve.
Cheers
