Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
This setting is "ON" by default in G-Post. If you need to enable it or make changes, open the Option File Generator, File Format menu, Sequence Numbers sub-menu. Everything you need is right there.
Fred Nemecek
Austin N.C., Inc.
