N-CODE
byron.taylor
N-CODE
I am trying to output the block numbers at the beginning of each block.
(e.g. N1...,N2....) what do I set in the Option File Generator for this?
This setting is "ON" by default in G-Post. If you need to enable it or make
changes, open the Option File Generator, File Format menu, Sequence Numbers
sub-menu. Everything you need is right there.
Fred Nemecek
Austin N.C., Inc.
