NPT holes
ptc-5137910
NPT holes
How do we model NPT holes in Parametric 2.0?
Is there a text file that we need to add?
H. Bostanci
Create a hole using the hole feature and select the options >> created standard hole >> adds tapping >> create a tapered hole. Under thread options the tapered holes should become available unless in your config.pro settings you are referencing a hole table directory which does not contain the default NTP.hol file.
Hope that helps,
- J -
Hope that helps,
- J -
Thanks a lot. I realized I was not selecting the tapered hole option, so NPT was not available in the drop down menu.
H. Bostanci
