Naming Datums Created In A Sketch
dgschaefer
Creo 3, M070
I have a sketch with several coordinate systems in it.  Once the sketch is complete, I want to change the name of those coordinate systems.  I know that I've done it as late as in Creo 2, but can't find the command in either Creo 2 or Creo 3.
LinkedIn
John.Pryal
(To:dgschaefer)
Hi Doug, i think you can do this through file/mass_properties
John
2 REPLIES 2
John.Pryal
(To:dgschaefer)
John
That's it, although technically it's File > Model Properties.
LinkedIn
