No Layer Isolate in WF4??
HugoHermans
What happened with Layer Isolate in WF4, see screenshot attached? Is there an option to make it available again?
Regards, Hugo.
<< ProE WF3 M190 - PDMLink 8.00 M040 >>
14 REPLIES 14
Hi Hugo,
This bothered me too. I asked Glenn Beer who did a presentation on Layers at Tampa (2007) where he promoted the use of Isolate. He thought it was there but then came back with this reply...
"Oh! Yes! You can drag the isolate icon from the customize dialog into the text menu View>Visibilities. Where it becomes a new line item there."
Why it is visible in the custom dialogue box and not in the menu in the first place I have no idea. Makes me a little worried that some folks at PTC do not really understand what Isolate does so do not worry about having it available (we thought we had lost it with the move to WF). I would like it on my RMB along with Hide and Show for layers. In the end I have also put the icon for Isolate in with all the other Layer Icons in my config.win. After suggestions from Glenn I have all my visibility Icons (datums etc, Layers, Views, View Manager) in a toolbar on the far left of my screen to the left of the model tree. His rationale is that this means the icons are always in the same location and I like this.
Regards, Brent Drysdale
Mechanical Designer
Tait Electronics Ltd (www.taitworld.com)
New Zealand
Ph. +64 3 358 1093
Regards, Hugo.
PTC took it off the stock UI. You need to customize a tool bar to include
the Isolate icon. It looks like an eye inside a dashed box. BTW It may not
grouped with the other display status icons of hidden and unhidden.
By not being grouped with, I'm talking about where the icon sits in the config.win customize dialog.
Hugo,
I blame PTC's documentation. Everything in the online help, for layers, is
absolutely accurate, and absolutely useless for learning. It is convoluted,
it tries to describe the visibility results in terms of the layer UI
functions only. That is not enough. I can't help but believe that the
original author, didn't get it.
The documentation ignores the difference between features and entities. This
dates back to when PTC was trying to differentiate Pro/E from all the other
Cad programs. "Pro/E has Features, not entities" - I heard that many times.
With that statement, Trainers couldn't talk about the difference. Or just
didn't know. It amounts to the same thing.
The documentation also ignores how layer status interacts with basic rules
governing *inherited invisibility*.
*Inherited invisibility *simply means that if an object is invisible,
everything that makes up that object is invisible.
Assy>parts>features>entities.
With this, an item on a layer, can impact the visibility of items not on
layers. Isolate is particularly powerful in this respect. This makes it much
more useful than many give credit. I find it troubling, when I hear of
people writing complex sets of layer rules, when by adapting to the use of
isolate, only one rule per layer may be needed.
Unfortunately, I don't think PTC will fix the documents, until there is a
groundswell of enlightenment among the general population of users. Then it
won't matter anymore.
On Mon, Mar 9, 2009 at 12:30 AM, Hermans Hugo
<->wrote:
> Thank you, Glenn. Now you and someone else mentioned it, I remember it
> was on the mailing list some months ago. I hope PTC wont drop it completely
> in the future (although I have to admit it's use isn't widely spread).
> Regards, Hugo.
I can't help but wonder if there isn't someone at PTC pushing for a
simpler UI, maybe looking at the competition. It's likely, as you said
Glenn, that they don't understand isolate. Only having show & hide
prominent makes things a lot simpler, at least they seem that way.
Layers are either on or off, right?
On, off and isolate is harder to explain and would lead to more tech
support calls to figure it out. Hard core users will call if we remove
it, but it's too hard to explain to novices, so let's bury it.
Too bad there's not a PTC or PTC|User wiki where users could document
some of this stuff.
Doug Schaefer
LinkedIn
Well let's be honest, here, the Pro/E help files have *never* been
useful for learning any aspect of the software. They are that way
intentionally - to promote a need for training and consulting.
Isolate in particular has been always been glossed over ever since I can
remember. Out of all the users I've encountered over the past 15 years,
I can count the number who had any idea what isolate does on one hand,
and have fingers to spare. I would wager that the reason it's not on
the latest UI by default is that PTC ran some audits to track how many
times a function was used, and if not used often enough, moved the
pick/button off the main UI.
Best Regards,
A Pro/E wiki? What a fantastic idea. Just think how much more useful
that would be that the built in help (which I also find sorely lacking
in most parts.)
I got this from Jeff Zemsky at PTC in January.
Wiki should be coming soon to the PTC/USER portal. The developer had is
planned for Q1 of 2009
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
As I remember, there was the intention to add a Wiki to the PTCUSER
portal. I still hope it will be available, some day.
Regards, Hugo.
There was a great presentation at PTC|User last year on how a company
used a Wiki to share Pro|E knowledge company wide. I guess it was
fantastically successful.
Doug Schaefer
LinkedIn
I wanted to shed some light on the decision to move (not get rid of) the
isolate command in Wildfire 4.0.
We've seen a trend by our customers to run with the layer tree undocked,
and when doing so mousing between the layer tree and the layer commands
in the view menu become excessive. Additionally, we sought to
consolidate some of the later control and accessibility menus. In
Wildfire 4.0, the layer commands (including Isolate) are now accessible
in the layer tree in the "Layer" menu (the screenshot is WF 5.0, the
word is replaced with an icon) as seen below.
Additionally, the command (as mentioned in an earlier post) is still
accessible for inclusion in toolbars for customization.
With regard to looking at alternative means of sharing information and
supporting Wiki's, forums, etc - these are all under active
consideration.
John
Why not use wikipedia itself?
Hi John,
Thanks for explaining where the cheese was moved to.
When I looked in the menu mapper from WF2 to WF3 and WF3 to WF4 the visibilities menu was greyed out indication no changes. I only found the icon in the customise screen after discussing with Glenn Beer.
What I would really like to see is that the RMB menu comes up with exactly the same menu as the LAYER drop down menu you mention. For some reason the Isolate command is missing from the RMB menu. I suspect that other users of the Isolate command would like to see this too.
Mechanical Designer
New Zealand
Ph. +64 3 358 1093
Buchowski, John wrote:I wanted to shed some light on the decision to move (not get rid of) the isolate command in Wildfire 4.0. We’ve seen a trend by our customers to run with the layer tree undocked, and when doing so mousing between the layer tree and the layer commands in the view menu become excessive. Additionally, we sought to consolidate some of the later control and accessibility menus. In Wildfire 4.0, the layer commands (including Isolate) are now accessible in the layer tree in the “Layer” menu (the screenshot is WF 5.0, the word is replaced with an icon) as seen below. Additionally, the command (as mentioned in an earlier post) is still accessible for inclusion in toolbars for customization. With regard to looking at alternative means of sharing information and supporting Wiki’s, forums, etc – these are all under active consideration. Thanks,John From: Doug Schaefer [
John,
I have not used the Isolate function in years. This thread got me
looking into it again. Perhaps I know why I dropped its use (we are on
WF3 / M170):
In Part mode -- Isolate works as advertised EXCEPT: Items that have
been selected and hidden manually (on the "Hidden Items" layer) always
stay hidden, even if a layer that contains them is Isolated. The
"Hidden Items" layer cannot be isolated.
In Assembly and Manufacturing modes - I would expect Isolate to be a
fast method to "de-clutter" the display and show only the layered items
we are interested in. HOWEVER:
Isolating a layer (or sub-layer) only impacts the display of datums in
the component that contains the layer. All other components continue to
display "clutter" as per their hide/unhide status.
To "de-clutter" the display, we still have to select all other
components and Hide their features.
In Manufacturing mode - Behavior is the same as Assembly mode.
ADDITIONALLY: The layer tree icons don't refresh properly when using
"reset status". You have to force it to refresh by manipulating the
layer tree.
Dave Ford
NC Programming Mgr.
G.W. Lisk Co.
Clifton Springs, NY 14432
(315) 462-4381
P Please consider the environment before printing this email - be green,
keep it on the screen!
