OUT PUT FILES
rusty.schulke
OUT PUT FILES
Is there a way to get pro-e to put certain file extensions into a specific folder ie err, crc, out_log etc........ or is there some other option with these? thank you
or is there a way to turn these off from being created
You can delete this kind of file automatically with Spekan Purge : ftp://proe:engineer@celkunststoffen.khlim.be/stud/Spurge_2.4.exe With this software you can also purge Pro/E files to keep only latest versions. Just select the root folder ans all subfolders will be cleaned.
purge is ok, but delete is not work,why?
why hasnt ptc spent the time to build something like this into your software 1 guy could write that in 1 day maybe theres a good reason but im starting to wonder why such an easy program to create and incorporate into wildfire isnt there by default not that the others have it either but the others do not spit out 50 some dif file extensions either
