Opening files - all versions - WF2
unknown1
Gurus,
I recall being able to choose to see "all versions" of a file
by clicking on the "white plus-black arrow" icon in the upper right
corner
of the file open dialogue box.
Did this move?
Where is this capability in WF2?
Mike Singer
Opening files - all versions - WF2It's still there. Works for me WF 2.0 M140.
Randy Speed
President and CEO
Speed Consulting, LLC
(972) 938-0490 ph (972) 937-2319 fax
www.speedconsulting.com
Mike,
If you are using Windchill or intralink you will not be able to see all
versions. Also, be sure that the directory you are looking in is not
being purged thru some batch file. We use one here that starts pro and
before it does it erases the trail directory. Hope this helps.
Chris Bennett
Sr. CAD Tech
Stryker Instruments
269-323-7700 x 4012
Chris.Bennett@stryker.com
_____
