If you found an answer, don't forget to mark it as correct for those that follow behind and search on this topic.
Thanks, Dale
Note:
@O can be applied on dimensions created in a drawing, only (@O can't be applied on shown dimensions created in a model).
Martin Hanak
Theres is also a discussion on this with the title "How to show text instead of dimensions without overwriting?" which may help you..
