Overwriting Dimensions
RENEVDMERWE
Hi Sometimes I have the need to overwrite the dimensions. How do I go about doing this,because I tried to do it in the properties but it doesn't take away the original dimensions. Any help is appreciated Thanx
5 REPLIES 5
REPLACE @D (dIM) W/ @O (OTHER) THEN ADD WHATEVER YOU WANT
Thanx a million Jamie
Dale_Rosema
(To:RENEVDMERWE)
If you found an answer, don't forget to mark it as correct for those that follow behind and search on this topic.
Thanks, Dale
Note:
@O can be applied on dimensions created in a drawing, only (@O can't be applied on shown dimensions created in a model).
Martin Hanak
Martin Hanák
Theres is also a discussion on this with the title "How to show text instead of dimensions without overwriting?" which may help you..
