PDMS VS CREO
visu
PDMS VS CREO
Dear Folks
Did any one aware of PDMS?
is't possible to work in creo = PDMS?
thanks in advance
Viswanathan.K
TomD.inPDX
(To:visu)
These are two different functions. Typically, the PDMS is a place that manages the files created by Creo.
But my question is?
the way pdms was multi user working enviorment.
is't possible same? in creo?
dschenken
(To:visu)
Ask a much longer question.
Ask someone with better English to help translate.
I think you have a good question but the translation is not good.
StephenW
(To:visu)
PDMS is a usually associated to plant design, especially piping design. Plant Design Management Software and is extensively in chemical and energy plants.
PDM is an abbreviation for Product Data Management. Creo uses PDMLink and formerly used Intralink and Pro/PDM. UGNX uses Teamcenter. Solidworks uses Enterprise PDM. You can mix and match PDM systems with design softwares but it usually requires some sort of 3rd party integration.
Not sure which one you are refering to.
