Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
thanks I will try it ... because i need to send some file to other people wich don#t have Proengineer ... and always is a problem form them to view the files.
