PTC Controls
etae
PTC Controls
Does anyone know the keyboard controls to allow you to travel around your model without having to resize your screen? The control is supposed to allow you to drag your mouse to the desired position.
1 REPLY 1
TomD.inPDX
(To:etae)
Your keyboard needs the middle mouse button. You can hold this and use the touchpad to rotate the part. For the keyboard joystick, you still need the middle mouse button programmed somewhere.
In perspective settings (render), there are some advanced orientation options, most of which I find completely annoying.
You can control spin centers by using the default; turning off the default and clicking on a feature and dragging the mouse, or selecting an alternate spin center with the view dialog.
Welcome to the forum, Ethan.
